Viz to 2D?
Bret Bullough
if you want to output it at a specific scale, you can draw a rectangle about the same size as your output in viz, for example, if it's 1:100, and your output is 40cmx50cm, just draw a 40mx50m rectangle in viz put it in front of the elevation and make an outside outline turn it into mesh to make it renderable. then render the view. load the rendered image in photoshop, select only the inside of the 40mx50m square and crop it. set up the image size to 40cmx50cm(you may need to resample if the resolution is less than 200dpi), you 'll get a real 1:100 image. you can resample to what ever scale you want based on this image. if you want a 1:200 image, resize the image to 20cmx25cm.
  • 3 years later...
Im desperate for something to do this for me!
This is where sketchup truely shows its power as a building modeller. The snap tools are efficient and easy, and you can generate line drawings with high detail as if it were a snapshot.
I suggest you export your file as a 3ds, and import it into sketchup, then use the section plane tool, then export>2d dwg, sorted. It wont be 100% clean, but still very good!
