blaz Posted April 14, 2004 Share Posted April 14, 2004 hi, when you outsource your work to a viz company from arch firm.. do you give your complete files (max+map) to your outsource? when there are a lot of non standart mapping. are they suppose to figure out, from the arch firm rendered image? please advice, how is the proper practice code... thanks Link to comment Share on other sites More sharing options...
Iain Denby Posted April 14, 2004 Share Posted April 14, 2004 Blaz I work as a freelancer, and all I get from the architects is a set of *.dwg files and maybe prints too, together with notes for materials to be used. That's it! Link to comment Share on other sites More sharing options...
Jim Mann Posted April 14, 2004 Share Posted April 14, 2004 Blaz, Having worked on both sides of the industry I would recommend that you give them absolutely everything you can - model, textures, drawings, samples, etc. Chances are they may do their own textures and amend the mapping, but the more information you can provide up front, the better the end result should be. The only exception to this would be if you have items from model and texture libraries within your scene. You should take out anything that you have bought from another source e.g. models of cars, texture maps of trees or people. Jim Link to comment Share on other sites More sharing options...
blaz Posted April 15, 2004 Author Share Posted April 15, 2004 thanks guys for your quick reply.. i'll see what this outsource comment about it. and i agree with dibber dwg and print out should be enough for them to work from any way, thanks for all your advice. Link to comment Share on other sites More sharing options...
