aflack Posted April 14, 2004 Share Posted April 14, 2004 I have attached a small white texture .bmp file as the background and I have also applied it to the envirnoment map. The background renders white but the reflection in the floor and ceiling renders as black. Any ideas why it isn't rendering as white? Thanks for your help! Link to comment Share on other sites More sharing options...
rivoli Posted April 14, 2004 Share Posted April 14, 2004 i can't see the point of using a map as environment if you only need white reflections. just set the environment color on white. if you want to use a map instead just make sure that spherical environment is checked. Link to comment Share on other sites More sharing options...
aflack Posted April 14, 2004 Author Share Posted April 14, 2004 It still doesnt work if I set to Spherical Envirnonemt. I assume when you say just set the envirnment colour to white you mean the little Background Colour tab next to the the envirnment map one? You will have to excuse me I am really new to this. It doesnt make any difference which way I do it using an white envirnment map or setting the background colour to white the reflections still come out dark. I achieved it before but now I can't duplicate the same affect. I've attached two little images showing what I want to achieve the one on the right is the one I want. Thanks. Link to comment Share on other sites More sharing options...
rivoli Posted April 14, 2004 Share Posted April 14, 2004 yes, that is what i was referring to. that's strange, it should work. can you please post the settings of your material? this might help us to understand what is the problem. Link to comment Share on other sites More sharing options...
aflack Posted April 15, 2004 Author Share Posted April 15, 2004 I am using the MentalRay renderer and the settings for the floor are attached. Link to comment Share on other sites More sharing options...
rivoli Posted April 15, 2004 Share Posted April 15, 2004 strange, i just tryed with your settings and it works just fine. no background map, just white enviroment, and final gathering. no direct lights. try using a raytracing material with a fresnel falloff in the reflection slot instead of an architectural material and see what happens. Link to comment Share on other sites More sharing options...
aflack Posted April 15, 2004 Author Share Posted April 15, 2004 If I delete the light from my scene you can see the whiteness or more of a greyness in the reflections. Is there a way to illuminate the background colour so its a lot brighter so the whiteness will be more apparent. Thanks. Link to comment Share on other sites More sharing options...
rivoli Posted April 15, 2004 Share Posted April 15, 2004 i don't know, it really depends on your lights settings, mainly indirect in this case. i'd try to make the material more reflective. Link to comment Share on other sites More sharing options...
aflack Posted April 15, 2004 Author Share Posted April 15, 2004 Thanks for yoru help rivoli. I just can't understand how I didn it before yet can't do it again. Link to comment Share on other sites More sharing options...
rivoli Posted April 15, 2004 Share Posted April 15, 2004 anyway, you need both direct and indirect light. your scene is quite dark at the moment. you should judge the reflectivity of floor and ceiling after setting the right light type. Link to comment Share on other sites More sharing options...
aflack Posted April 15, 2004 Author Share Posted April 15, 2004 I'm not sure if it has anything to do with direct illumination if I turn it off and just use the mental ray renderer to render the screen the reflections render as almost black. What type of light would you recommend I have tried teh Sunlight system and a target light but neither make any difference. Link to comment Share on other sites More sharing options...
aflack Posted April 15, 2004 Author Share Posted April 15, 2004 If I render the same screen using the scanline rendered then the reflections render as white as seen in the attached image. So it is pretty much something to do with the mental ray settings. Any ideas? Thanks Link to comment Share on other sites More sharing options...
