archkre Posted April 15, 2004 Share Posted April 15, 2004 Does the default Vrlight multiplier value=1 work well for feet w/inches unit settings only? If I use milimeters do i have to modify that default value? Thank you Link to comment Share on other sites More sharing options...
Craig Ramsay Posted April 15, 2004 Share Posted April 15, 2004 I use millimeters and have never had any problems with it. Give it a bash and see if it works for you. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted April 15, 2004 Share Posted April 15, 2004 What unit system do you work with? If you work with meters, you can simply set the System Units to 1 unit = 0,025 meters That'll make Max work in meters, but also will convert units to their metric correpondents. Then, you can work with any application (not only VRay, but RPC, Onyx TreeStorm, etc...) without having to worry with units. [] Rick Link to comment Share on other sites More sharing options...
