bobmaxer Posted April 19, 2004 Share Posted April 19, 2004 i am working with brazil render with 3dsmax and i find it not rendering a wireframe material, did anyone out there come across the same problem?? Link to comment Share on other sites More sharing options...
rivoli Posted April 20, 2004 Share Posted April 20, 2004 in fact it does not. as long as i know brazil can't force wireframe as the scanline does. Link to comment Share on other sites More sharing options...
Craig Ramsay Posted April 20, 2004 Share Posted April 20, 2004 You can yse the lattice modifier in max to kind of work around the problem but it creates a lot of geometry. Craig Link to comment Share on other sites More sharing options...
Christopher Nichols Posted April 20, 2004 Share Posted April 20, 2004 there is also a procedural texture map you can use called wiretex.... go here and look up WireTex: http://www.maxplugins.de use it to make a transparency map. Not as good as the real thing, but it can work in a pinch. Link to comment Share on other sites More sharing options...
