wsneto Posted April 19, 2004 Share Posted April 19, 2004 Hi folks Please, I really need your help adjusting my image. I´ve tried really hard doing this but here goes my best (or less worst) image. There goes my informations: Viz Radiosity Solution quality - 70,86% Refine - 10 filtering - 2 radiosity meshing - 0,5meters Sunlight - IES Sun 110.000lux (the sun here is really bright like this) use global settings checked affect surfaces contrast = 100 IES Sky - 1,5 sky color - white sky clear Difuse illumination checked cast shadows checked exponent 25 rays per sample 4 ray bias 0 If you have comments about other stuff, please, do it! Help! I need somebody! Help! Link to comment Share on other sites More sharing options...
omerselcuk Posted April 19, 2004 Share Posted April 19, 2004 hi... idont see any problem in your model. u can work for textures and lights for tis image. 2 points 1-it seems you have only sky lighit in your schene but the backround image is more sunny day. my suggestion is increase the value from skylight, create a spotlight with strong shadow. it can bring your image in live. 2-the stone texture in floor is not really realistic, im sure i could play with it. Link to comment Share on other sites More sharing options...
bio2000 Posted April 20, 2004 Share Posted April 20, 2004 Hi there! The overall problem i think is in light and textures. The main thing is that your light is bright but the shadows doesnt match. You should try to add a spotlight to simulate sun, with raytraced shadows! (Look out of your window if its sunny at your place, your shadows should be sharp!!!) Another big problems are you textures!!!!!!! Try to mix at least 2 for the front pavement, so you wont see the tiling anymore. And last but not least, i think your horizont line looks weird, your terrasse is going higher than the horizont, that looks odd to me! Hope this helps. Link to comment Share on other sites More sharing options...
Ernest Burden III Posted April 20, 2004 Share Posted April 20, 2004 You also are having the common problem of your background horizon not matching the view horizon. That will help. Also, the paver texture is tiling badly. The red on the roofs seems too bright and saturated Link to comment Share on other sites More sharing options...
