alastair Posted April 23, 2004 Share Posted April 23, 2004 when you use an image as a backround ,why does Max render the reflection 2d? The background image just continues through the objects. In other words the reflection on objects seem as if they are part of the 2d image of the bakground ,if that makes sense. This is really bugging me. Thanks in advance Link to comment Share on other sites More sharing options...
Iain Denby Posted April 23, 2004 Share Posted April 23, 2004 You probably have the rfelction map set to 'screen' which projects your map through the geometry. Set it to texture Link to comment Share on other sites More sharing options...
tenderfoot Posted April 27, 2004 Share Posted April 27, 2004 u can use the geosphere method, make one check hemisphere and slap the image unto the object, that way you can, toggle the background image whichever way u want Link to comment Share on other sites More sharing options...
