MegaPixel Posted April 24, 2004 Share Posted April 24, 2004 Surely there are some of you who don't do Architectural Modeling all of the time. I just happened acrossed some Engine Exhaust and Smoke system tutorials on the Net and told myself that I had to play a little. But before I get started with the F/X tutorials, I thought I better create something a little more detailed then a cone to represent a Rocket engine. So here's what I've thrown together so far. It is a WIP however - I'm thinking about adding some outriggers on the sides with more maneuvering engines and stuff. Anyhow, I kind of cheated when I modeled the outer Hull shapes. I made them in Solidworks rather then MAX (Happens to be my more comfortable modeling app). So... I imported the objects into MAX via .stl format, used autosmooth with a 30 deg. smooth angle default. As you can see, there are some occasional smoothing anomilies, not many, but they need cleaned up none the less. Normally when I model houses and such, I never run into the kind of advanced curvature smoothing issue. My question for you is how do you recommend cleaning an imported model like this with respect to smoothing groups? When do you know to use different angles and where to start and stop them? I've always struggled to understand just exactly how they work. Thanks in advance and plz offer some suggestions. thanks - Mega Link to comment Share on other sites More sharing options...
Ras Posted April 24, 2004 Share Posted April 24, 2004 Very cool! Link to comment Share on other sites More sharing options...
Fernando Lino Posted April 25, 2004 Share Posted April 25, 2004 nice mode....it looks like a futuristic shark Link to comment Share on other sites More sharing options...
MegaPixel Posted April 27, 2004 Author Share Posted April 27, 2004 Just thought I'd post my Modeling Tweaks to this thing. Now I believe I'm ready to texture this thing and compose a compelling scene... Any thoughts? Link to comment Share on other sites More sharing options...
mallku Posted May 2, 2004 Share Posted May 2, 2004 cool guy this machin is a goodone.... its good to practice in a fx model... when i saw your model i remenber a protos carrier did u play start craft? keep working and posting i think the textures will give a good look at your model Link to comment Share on other sites More sharing options...
skogskalle Posted May 2, 2004 Share Posted May 2, 2004 awsome! I really like the wing you added, looks mighty fine =) cant really complain about anything at this point.... make sure you post the textured version though, its gonna look great. I allways model everything in MAX, but Im afraid Im no master when it comes to smoothing groups. Im sure there are some guidelines or rules you can follow, but I usually go by the old Trial n error technique.... takes time, but sooner or later it always ends up ok.... Link to comment Share on other sites More sharing options...
UltraCadViolet Posted May 26, 2004 Share Posted May 26, 2004 reminds me of something from starwars. i think as a background, you could even put it underwater with bubbles.. or out in space yep. do post the work in progess. i like.. Link to comment Share on other sites More sharing options...
