skogskalle Posted April 27, 2004 Share Posted April 27, 2004 I recently downloaded Vray Free... Absolutely awsome, but one little thing bothers me... I rendered an exterior animation as a test today, and I get a lot of flickering in the darker areas of the anim. I guess this is because the Irradience map is calculated for every frame and doesnt turn out exactly the same every time (I have the irr map set to "very low" btw) so...will this problem go away if I use Vray adv, and re-use the same irr map for the whole animation? Link to comment Share on other sites More sharing options...
salf Posted April 27, 2004 Share Posted April 27, 2004 theres a lot of info about this on the vray forums, go there, you'll find an answer. http://www.chaoticdimension.com Link to comment Share on other sites More sharing options...
