Acad solids triangulate in Max
Noise
Hi
When I import Autocad solids into Max 4.2 it triangulates the solids in Max causing an unnecessary large number of faces to be generated with no additional detail.
Does any body know how to prevent this happening ?
Thanks for your time.
Regards
N
like ernest said, everything is triangles. but if you don't want them all to show (they'll still be there) go into Edge sub-object mode, select all, and click on Auto-Edge. that'll make all the triangle strip edges go invisible.
Habware have free .obj import/export plugins for max. can't remember the link off-hand but they might be on http://www.maxplugins.de
IC,
I just tried it again and it worked without any problems. I did some boolean operations on a box using spheres and boxes in Autocad 2002. I then imported that booleaned object as a .dwg into MAX 6.0 and had no tesselation occuring.
I make sure my surface deviation is set at 0". I find that the objects imported are much smoother than the default setting. I had a lot of problems importing my plines into Max with the default setting....
Hockley91
IC,
Hockley91
Surface deviation at 0 is fine, but generates the most triangles. Avoid it when doing a large scene with lot's of curved surfaces in AutoCAD.
The import of AutoCAD Solids into 3ds max 6 works fine and there are much less troubles as there used to be.
I thought this thread was going to solve a problem I have, but I didn't. I am working in Max 6 at work, and there when I draw a box it does not display the triangulation of the geometry but at home, I am working in Max 5 and when I draw a box the geometry apears triangulated on the screen. Is there a setting that I can turn off so I don't have to see the triangulation. I have search the help with no luck...
thanks
munz
