BHR Posted April 29, 2004 Share Posted April 29, 2004 While rendering straight lines am getting a repeated cured look. I happens alot with the brick. I was wondering if anyone knows how to minimize this. I am using viz 4 Thanks Link to comment Share on other sites More sharing options...
STRAT Posted April 29, 2004 Share Posted April 29, 2004 can you post up an image to illustrate please Link to comment Share on other sites More sharing options...
Chad Warner Posted April 29, 2004 Share Posted April 29, 2004 I'm guessing it is a moire pattern that you are seeing. You should be able to fix it by playing with the Anti-Alias settings. Try catmull-rom. The other option would be to super-sample the material. Link to comment Share on other sites More sharing options...
STRAT Posted April 29, 2004 Share Posted April 29, 2004 As Chad says, if it's a mesh thats the offender then AA settings are the solution. if it's a material problem then use SS. Link to comment Share on other sites More sharing options...
