Archicad to Maya
  • 10 months later...
Unfortunately when you export from archicad to maya due to the fact you are sharing multple faces, maya convert the model to one piece. The only way you could do that without problems is exporting it to 3dmax7 and from them break the model into multiple pieces and reexport it to maya as a .obj file, and there you should put the materials directly selecting the polyfaces, a harder labor. :o
  • 4 weeks later...
I currently use Archicad, and M aya to render. I save out from AC using the 3ds format, which will let you group your model according to either texture type, layer type or as a single model.
Using this method, alls you need to do is assign certain materials in AC that you would want to keep grouped together in Maya
