neill Posted May 2, 2004 Share Posted May 2, 2004 im trying to export a 3d site to dwg. but everytime i do it is 2d instead of a 3d model... anybody have any ideas? im actually trying to export it to dwg to bring it into sketchup, because sketchup doesnt imort 3ds. so if anybody has ever done this. let me know. thanks neill Link to comment Share on other sites More sharing options...
Ras Posted May 2, 2004 Share Posted May 2, 2004 Hi Neill Sketchup doesn´t accept solids or anything like that - only faces. When working in Architectural desktop you can convert everything to mass elements and that´l work but only if you export to autocad 2000 format. Sketchup will not take 2004. Last recommends exporting to 3ds format from ACAD importing the 3ds file back into ACAD and saving as dWG(2000). This will explode all your solids to faces. Take a look at the Sketchup website - they have some great tuts... Link to comment Share on other sites More sharing options...
Onslaught Posted May 2, 2004 Share Posted May 2, 2004 You have to be in a 3D view in order to export the 3D model into AutoCAD. This works on Revit 6 (what version do you have)? Link to comment Share on other sites More sharing options...
Richard McCarthy Posted May 2, 2004 Share Posted May 2, 2004 Neil, open your 3D view in Revit, and now goto Export and export it. It's weird but that's how Revit work, when you are in 2D view (eg plan, elevation) it only export 2D view. In 3D view, it export 3D So, goto ANY 3D view, click File -> export -> DWG,DXF,DGN, export to DWG, remember to export to AutoCAD "2000" DWG file..., I think DWG exports better than DXF. (But the choice is yours, experiment with it. Another thing, sketchup do not support autoCAD 2004 yet, so don't export to 2004) Now, goto Sketchup, -> File -> Insert -> DWG/DXF, click the relevent units for importing it in, and import. Once imported in, click View -> Zoom -> Extent to see the model imported in properly. I am pretty sure this process even works with older version (eg. 4.5, 5.1, etc) but for 6.0, 6.1 it still works wonderfully. Another thing... when I goto ANY 3D view.. if you are exporting this to autodesk VIZ4, or 3DSMAX, the 3D View you chose to export to, eg with particular camera angle, it will also be exported. So if you already have a good 3D view setup in Revit, you can export the whole 3D model to DWG and get it imported to VIZ4 and load up the correct camera. Link to comment Share on other sites More sharing options...
neill Posted May 2, 2004 Author Share Posted May 2, 2004 thanks guys, im going to try all of these and see if i can get it to work... ill let you know what i come up with Link to comment Share on other sites More sharing options...
