stylez Posted May 5, 2004 Share Posted May 5, 2004 Hello everyone, I'm working on this interior, but when I render I'm gettting these huge splotches everywhere. I've tried everything i can think of, but they won't go away. I changed all Raytraced maps to vray maps, there's no glass in the scene, everything has UVW mapping, all maps are cropped. If anyone knows how to help me, please let me know. thanks in advance - Stlyez Link to comment Share on other sites More sharing options...
Noise Posted May 5, 2004 Share Posted May 5, 2004 I would recommend that you open a new model and merge all the geometry, lights etc into it. You will have to setup the vray parameters again but think it is better than trying to work with what you have got. N Link to comment Share on other sites More sharing options...
stylez Posted May 5, 2004 Author Share Posted May 5, 2004 i already am using single frame Link to comment Share on other sites More sharing options...
stylez Posted May 5, 2004 Author Share Posted May 5, 2004 here's the render settings.... Link to comment Share on other sites More sharing options...
Chad Warner Posted May 5, 2004 Share Posted May 5, 2004 Check the VRay log screen that pops up while rendering. There might be some errors in there that will help point to the problem.....check that your bitmaps are cropped, and that anything that has a material applied has a UVW map applied to it. -Chad Link to comment Share on other sites More sharing options...
stylez Posted May 5, 2004 Author Share Posted May 5, 2004 Chad Warner; there's no errors in the Vray log, and all maps have UVW applied.. mark; I've applied all the changs you said, except the last one - I have no idea what or where it is. anyways it's rendering right now - it should be posted in a few seconds.. Link to comment Share on other sites More sharing options...
stylez Posted May 5, 2004 Author Share Posted May 5, 2004 i got smaller splotches ... but still splotches Link to comment Share on other sites More sharing options...
stylez Posted May 5, 2004 Author Share Posted May 5, 2004 found it .. re-rendering now no, it never rendered good, it always had these splotches... i never had this problem before Link to comment Share on other sites More sharing options...
stylez Posted May 5, 2004 Author Share Posted May 5, 2004 SPLOTCHES ARE GONE!!! :) thank u soo much, i really appreciate this.. especially considering i had till the end of today to fix this problem thank u so so much - Stylez Link to comment Share on other sites More sharing options...
stylez Posted May 5, 2004 Author Share Posted May 5, 2004 can u tell me what the shade contect thing does? how did it get rid of the splotches for me?? thnx Link to comment Share on other sites More sharing options...
salf Posted May 5, 2004 Share Posted May 5, 2004 now you gotta work on those splotches, play with the irr. map settings, in this link you'll fond help on how to reduce the splotches and the artifacts you were getting before: http://www.metinseven.com/article_vray_splotches.htm Link to comment Share on other sites More sharing options...
stylez Posted May 5, 2004 Author Share Posted May 5, 2004 lol, i was at that site before i posted here, i tried everything it said to do, but the only thing that got rid of those splotches was the shade context thing Link to comment Share on other sites More sharing options...
stylez Posted May 5, 2004 Author Share Posted May 5, 2004 ah true, thanks for your help mark, i really appreciate it. I've never had someone respond as quickly as this forum did - usually i have to wait a day or 2 to hear from someone (threedy.com forums) anyways thanks again everyone, - Stylez http://www.artwix.com/rei Link to comment Share on other sites More sharing options...
stylez Posted May 5, 2004 Author Share Posted May 5, 2004 here's the almost final - just gotta brighten it up... Link to comment Share on other sites More sharing options...
stylez Posted May 5, 2004 Author Share Posted May 5, 2004 here's the final.. let me know what you think Link to comment Share on other sites More sharing options...
kippu Posted May 6, 2004 Share Posted May 6, 2004 nice ...i like Link to comment Share on other sites More sharing options...
stinkyz Posted May 9, 2004 Share Posted May 9, 2004 Try making sure that crop is enabled in all of your maps, even if your not using crop. Also chaoticdimensions.com Link to comment Share on other sites More sharing options...
