Autocad Wood Hatch Patch
Tony
  • 3 years later...
  • 1 month later...
hi jim
It is simplier to copy the wood.pat file into the "C:\Documents and Settings\"the user you have logged in"\Application Data\Autodesk\AutoCAD 2007\R17.0\enu\Support and you will find it at custom hatch. Custom hatch is an alternative to user defined and predifined
good luck
  • 1 month later...
Hola,
So I'm working in AutoCAD 2007 and this is what I did. It's fairly simple
#1 Created a Folder in my CAD Standards Folder called Hatch
#2 I renamed the pat file to be called hardwood since that is the name that is inside the pat file and they need to match.
#3 In Options, I added the folder that I previously created in the the Support File Search Path
#4 Finally I went to the hatch command, where it calls the pattern I pressed the icon with the 3 dots and went to custom and there it was. I selected the hardwood pattern and that was it.
I hope this was helpful.
Elsa
  • 4 weeks later...
well if anyone is interested i have about a hundred or more custom hatches. If anyone wants them let me know.
Also, the correct way to install hatch patterns in to AutoCAD 2007 is to go to:
mycomputer/programfiles/AutoCAD2007/support.
I wouldnt mind having them.
  • 3 months later...
  • 1 year later...
can you explain why this is the correct way?
i am thinking that the proper way is to create a new path from the option cammand. so when you unistall autocad you won't loose your hatch
