Tony Posted May 5, 2004 Share Posted May 5, 2004 Can anyone help me out with a descent wood hatch pattern for Autocad 2000. Thanks in advance! Tony trgraphics@direcway.com Link to comment Share on other sites More sharing options...
Onslaught Posted May 5, 2004 Share Posted May 5, 2004 try this hatch pattern....... Link to comment Share on other sites More sharing options...
Tony Posted May 6, 2004 Author Share Posted May 6, 2004 Thanks OnSlaught, I appreciate it! Tony Link to comment Share on other sites More sharing options...
AndyK Posted August 27, 2007 Share Posted August 27, 2007 Okay, now can anyone help me import the wood hatch into AutoCAD 2007? It is a complete mystery. Thanks Link to comment Share on other sites More sharing options...
jnorine Posted October 1, 2007 Share Posted October 1, 2007 I also need help inporting the wood.pat file. I tried to paste it into my acad.pat file, but it still doesn't show up. Thanks, Jim Link to comment Share on other sites More sharing options...
smarch Posted October 1, 2007 Share Posted October 1, 2007 hi jim It is simplier to copy the wood.pat file into the "C:\Documents and Settings\"the user you have logged in"\Application Data\Autodesk\AutoCAD 2007\R17.0\enu\Support and you will find it at custom hatch. Custom hatch is an alternative to user defined and predifined good luck Link to comment Share on other sites More sharing options...
moonguide Posted November 8, 2007 Share Posted November 8, 2007 Hola, So I'm working in AutoCAD 2007 and this is what I did. It's fairly simple #1 Created a Folder in my CAD Standards Folder called Hatch #2 I renamed the pat file to be called hardwood since that is the name that is inside the pat file and they need to match. #3 In Options, I added the folder that I previously created in the the Support File Search Path #4 Finally I went to the hatch command, where it calls the pattern I pressed the icon with the 3 dots and went to custom and there it was. I selected the hardwood pattern and that was it. I hope this was helpful. Elsa Link to comment Share on other sites More sharing options...
architect_js Posted November 8, 2007 Share Posted November 8, 2007 I get an error message in using this hatch file. something about a missing parameter? Anybody got it working... Link to comment Share on other sites More sharing options...
brandontw Posted December 5, 2007 Share Posted December 5, 2007 i got this hatch to work my changing the name of the file to "hardwood.pat" thanks! Link to comment Share on other sites More sharing options...
arachai Posted December 5, 2007 Share Posted December 5, 2007 well if anyone is interested i have about a hundred or more custom hatches. If anyone wants them let me know. Also, the correct way to install hatch patterns in to AutoCAD 2007 is to go to: mycomputer/programfiles/AutoCAD2007/support. Link to comment Share on other sites More sharing options...
brandontw Posted December 6, 2007 Share Posted December 6, 2007 arachai said: well if anyone is interested i have about a hundred or more custom hatches. If anyone wants them let me know. Also, the correct way to install hatch patterns in to AutoCAD 2007 is to go to: mycomputer/programfiles/AutoCAD2007/support. I wouldnt mind having them. Link to comment Share on other sites More sharing options...
Plato Posted March 22, 2008 Share Posted March 22, 2008 If you're willing to share, I'd be most appreciative! Link to comment Share on other sites More sharing options...
smarch Posted May 19, 2009 Share Posted May 19, 2009 brandontw said: I wouldnt mind having them. can you explain why this is the correct way? i am thinking that the proper way is to create a new path from the option cammand. so when you unistall autocad you won't loose your hatch Link to comment Share on other sites More sharing options...
