stone145 Posted May 12, 2004 Share Posted May 12, 2004 hi all, my friend's hard disk just crashed and it has valuable information in it, is there a way to get the info back from it? the computer just dont recognize the disk, and says it has no format! i hope there's a solution for this! Link to comment Share on other sites More sharing options...
graphix Posted May 12, 2004 Share Posted May 12, 2004 I would try a few things first to make sure the HD is really bad. First change out the ribbon cable Second try the HD in a different computer. If both of those fail you will more then likely have to send the drive to a hard drive recovery service. Mind you these services run in the thousands and don't always mean you get all your data back. Most places will charge a minimum to even look. graphix Link to comment Share on other sites More sharing options...
