BEKA Posted May 17, 2004 Share Posted May 17, 2004 I am trying to Array Track Tie along the Rails. I used Spacing Tool to get Array, but I have problem to have Tie perpendicular to Rail. Software: 3ds Max 6 If anybody have any idea how I can do it I would appreciate it very much. Thanks Link to comment Share on other sites More sharing options...
Jape Posted May 17, 2004 Share Posted May 17, 2004 Not exactly sure what you are trying to do, but try turning on the follow checkbox should work, it alligns the distributed object with the tangent of the spline Jape, Link to comment Share on other sites More sharing options...
BEKA Posted May 18, 2004 Author Share Posted May 18, 2004 For example, if I have curved spline and rectangle and I need rectangles to be perpendicular to tangents of the spline. Using spacing tool, I turned on follow check box but I cannot get it perpendicular. I hope my question is clear now. Thank you for respond. Link to comment Share on other sites More sharing options...
Jape Posted May 18, 2004 Share Posted May 18, 2004 trie placing the rectangle on the end vertex of the spline, then if they arent placed properly, rotate the rectabgles 90degrees en volia! it should work, Check the attached image jape, Link to comment Share on other sites More sharing options...
BEKA Posted May 19, 2004 Author Share Posted May 19, 2004 I will try that. Anyway thank you Jape. Link to comment Share on other sites More sharing options...
