Wampa Posted May 21, 2004 Share Posted May 21, 2004 Hi all, I started use VIZ 5 and have a litlle problem. I have a model of house in ADT 2004. I linked this house to VIZ 5 via File Link. Then I select one wall and assign from material editor material to this wall. But material was assigned on all walls. I try linked house from ADT 2004 with every method in File Link but every when I assigned material only in one wall material was assigned on all walls. This problem I have with glass in windows too. Where is problem ??? Thanks for advice.... Wampa Link to comment Share on other sites More sharing options...
bobsan Posted May 21, 2004 Share Posted May 21, 2004 Try putting the wall in it's own layer in Autocad that should do the trick. Link to comment Share on other sites More sharing options...
Tim Nelson Posted May 21, 2004 Share Posted May 21, 2004 Isn't there a material override command in Viz to apply only to single objects and not all objects on the same layer? I don't know cause I dont have Viz 5 yet but I think I read something about that. Link to comment Share on other sites More sharing options...
abicalho Posted May 21, 2004 Share Posted May 21, 2004 Materials Editor > Options > Propagate Materials to Instances Disable that and you will be able to apply materials individually. Alexander Link to comment Share on other sites More sharing options...
Wampa Posted May 24, 2004 Author Share Posted May 24, 2004 Materials Editor > Options > Propagate Materials to Instances Disable that and you will be able to apply materials individually. Alexander Yes. This is solution for my problem. Thanks. Link to comment Share on other sites More sharing options...
