camera views
STRAT
hi guys, may be a simple question, but something i've never pondered over until now.
cameras - i have a camera in my 3d app. max or c4d. how do i EXACTLY replicate this camera view in autocad?
i cant see where i can make controlable cameras in acad, or where i can import them from other apps.
is there a way?
If you can export a 3ds out of c4d, then you can select the camera and export that to a 3ds file. Then you "3dsin" into acad, and select the camera object. That will replicate exactly the camera location and lens, etc. I haven't been able to figure out how to get the aspect ratios of a rendered image and a perspective view in ACAD to line up perfectly yet though.
-Chad
Never could get ADT & Viz cameras to match. They're always off, just a little bit, not field of view, but ADT/AutoCAD always seems rotated up, go figure. Duplicted the camera position-exact piont to exact piont, field of view, rotation, I have been through all of the commands- tools bars- view- command line. I gave up trying two years ago, however if there is truely a way that would be really awsome.
WDA
WDA
yup, exactly my problem
  • 1 month later...
This is the reverse order of things, but someone in the Viz Autodesk discussion forum went successfully from ACAD to VIZ and changed the MM of his camera by 1 MM in Viz and was able to line up the rendered view and the ACAD view. I just tried it myself, and it seemed to work.....not EXACTLY the same view, but at least less tweaking between the two in Photoshop.
-Chad
