berkshirebuild Posted May 27, 2004 Share Posted May 27, 2004 I am trying to create color residential elevations or renderings using a adt and photoshop. I created a jpg plot driver to export my dwg files to photoshop but the jpg file always consists of large pixels. Does anyone know how to set up plot driver in adt so it creates a fine line quality file for photoshop? Also I am having a problem trying to insert hatches or patterns such as tile brick roofing concrete and so on in photoshop. Thanks James Link to comment Share on other sites More sharing options...
TheAllusionisst Posted May 27, 2004 Share Posted May 27, 2004 I would use the EPS via a Postscript plotter driver as I recommended in your ealier post, the quality surpasses any of my attempts to use jpg or other raster output functions. http://www.cgarchitect.com/vb/showthread.php?p=41742#post41742 My first response in this thread outlines it. Good Luck! Link to comment Share on other sites More sharing options...
STRAT Posted May 27, 2004 Share Posted May 27, 2004 autocad - photoshop = http://www.cgarchitect.com/vb/showthread.php?t=4045 Link to comment Share on other sites More sharing options...
Fernando Lino Posted May 27, 2004 Share Posted May 27, 2004 This my way If you want to get the elevation in scale I’d use Define the sheet size (ex. 11x17) 300dpi---the size would be 3300 x 5100 For architectural scale is dpi = 1 For engineer scale dpi= 12 And select the scale for the viewport. I use in every single color .7mm if I need to control the thickness I use a polyline with different width….for me it works and it is fast. Good luck Link to comment Share on other sites More sharing options...
