3D Plans Jason Posted May 31, 2004 Share Posted May 31, 2004 Hello everyone, I'm hoping to get a good amount of contructive criticism on this one. I think it has a lot of potential and I'd like to extract every bit of it. No comment is too harsh as long as it's followed by a suggestion for improvement! Thanks for the help Jason Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted May 31, 2004 Share Posted May 31, 2004 Silly question...aren`t the junctions between blocks a bit too transparent? Link to comment Share on other sites More sharing options...
3D Plans Jason Posted May 31, 2004 Author Share Posted May 31, 2004 Rick - not a silly question at all. You are correct, they ARE too transparent. Thanks. I know how to fix. Later. Link to comment Share on other sites More sharing options...
SEIF Posted May 31, 2004 Share Posted May 31, 2004 very nice...i like it alot...a very pleasing night mood u reached... my only comment is that i see the glass blocks toooooo frosted...c...maybe if u can decrase that would mak it much better... otherwis excellent work....gongrts... Link to comment Share on other sites More sharing options...
chuck Posted June 1, 2004 Share Posted June 1, 2004 this is a nice image... -the plant on the left looks a bit flat. not sure how to fix it. the right plant gets enough light that you can actually see the light hitting it from the camera angle. you could increase the specular level of the plant material...most plants are glossy. a few random omnis set to specular only might show the contours of the leaves then...maybe. -what is behind the plant on the right? a bad RPC tree? it looks off, and i doubt it would be that bright.. i'm guessing its being used to mask the space to the horizon line above? -the light on the right doesnt seem to be casting a shadow below it...shouldnt the base cast a shadow? hope i'm not nitpicking. the lighting looks nice. i love night shots. chuck Link to comment Share on other sites More sharing options...
Joel Gray Posted June 3, 2004 Share Posted June 3, 2004 This is great work. You could sell this as-is, but since you're asking, I would consider the following: 1. The texture on the wall seems a bit too large and glossy, especially if it's a stucco type finish. 2. The light hitting the ground feels too bright. 3. The light from the sconses feels too dim. Maybe even (dare I say) add a hint of lense flair or glow. These are just my preferences. As I said, this is great work. Keep it up... Joel Link to comment Share on other sites More sharing options...
joshuam1972 Posted June 19, 2004 Share Posted June 19, 2004 Unbelievable! I am very new to the rendering world am inspired to achieve higher levels of realism because of your "work in progress". How did you produce the glass block effect? Incredible! Link to comment Share on other sites More sharing options...
Pumuckle Posted June 24, 2004 Share Posted June 24, 2004 the plant on the right is maybe getting a little too much light, dont know how to fix it ... sorry Link to comment Share on other sites More sharing options...
