Tim Nelson Posted June 1, 2004 Share Posted June 1, 2004 I just installed Viz 2005 and I'm really liking it EXCEPT for one major problem. I can't seem to toggle between 1 viewport and 4 like I used to. I know the "W" key is now 'move', but even if I go into the viewport config. menu and choose 4 viewports, it will flash for a second, and then just go back to one. I don't think its a display driver because I've tried openGL and directX. Anybody else run into the same problem? Link to comment Share on other sites More sharing options...
Brian Cassil Posted June 1, 2004 Share Posted June 1, 2004 Try alt+W. That's how it is in Max 6 anyway which was different from Max 5. You can of course change the shortcut key back to W like I did. Link to comment Share on other sites More sharing options...
mbr Posted June 1, 2004 Share Posted June 1, 2004 I've had problems with that with Max 5.1 . It's only with models I get somewhere else, and it will flash to the 4 windows for a millisecond, then go back to the full screen. Alt+W ? I'll give it a try. Link to comment Share on other sites More sharing options...
Tim Nelson Posted June 1, 2004 Author Share Posted June 1, 2004 Well I finally got it figured out...somehow. I tried ALT+W before and nothing ever happened. Then after switching display drivers and trying again, it finally worked. Case closed! Link to comment Share on other sites More sharing options...
tcorbett Posted June 2, 2004 Share Posted June 2, 2004 Yeah, I found the restructure of the UI pretty annoying. I actually used the tabbed view all the time - now I will have to make my own custom version. I just turned my "W" key back to my viewport toggle. (Also my "E" key to Zoom Extents Selected) Here's a problem I am having - I have customized my interface to bring back some of the menus I miss, and have saved the custom ui, but everytime I open VIZ 2005, it reverts to it's old UI. My new key allocations remain, but the menus do not. Is this a bug, or am I just doing it wrong? Link to comment Share on other sites More sharing options...
