Visual Pieces Posted June 3, 2004 Share Posted June 3, 2004 hello i have to do animations of a project with 300 identical homes in one 3ds max 6 file. the question is: 1. i make 300 blocks in Autocad, copy 300 times in autocad... and then textures all 300 diferent layers in 3ds max. or 2. i make a single file and then copy 300 times in max. the dwg file is around 500 kb. can i manipulate this 300 blocks file? could i animate in reasonable time? wich is the best way to do this projesct? thanks Link to comment Share on other sites More sharing options...
abicalho Posted June 3, 2004 Share Posted June 3, 2004 Create 1 house, texture it in MAX, insert it 300 times as Xrefs. If you need to change it, you'll change it once and it'll update on the other ones. Alexander Link to comment Share on other sites More sharing options...
Scott Schroeder Posted June 3, 2004 Share Posted June 3, 2004 I think your best bet is to have several max files for this project. If this is a sub division I would break it up by streets. Becuase if you have 300 homes in one file, that file will be almost unmanagable for you to animate. Or render in layers with the homes on all different layers, such as homes that are close and homes that are in the background. Also if all 300 homes are the same, whats the point of showing them all? That is a waste of time. I realize this is a project but if you can tell what the other 299 are going to look like by just showing 1 then you could save yourself alot of time. Once this is done I would like to know how it went and how it looks. I wish you the best of luck. Link to comment Share on other sites More sharing options...
mbr Posted June 3, 2004 Share Posted June 3, 2004 I agree, it seems odd that someone would want to advertise that they are making 300 cookie cutter boxes. A shame, really, but that's another discussion. Plan the animation - are you going to show all of them in one animation? Or composite a bunch. I'd say the XRef is the way to go, it's quick and works well. I'd think about having maybe 3 levels of detail for the homes and three XRefs. That way you could show the ones closest to the camera with detail and those farther away with less. Link to comment Share on other sites More sharing options...
Visual Pieces Posted June 3, 2004 Author Share Posted June 3, 2004 the project is a new urbanization: 300 homes 1 school 1 comercial center green areas, etc the first stage of my work will be a picture of 20 m2, to put in the place. then i have to do some animations showing all project. abicalho: u mean make the model of the house, texturize perfectly and then xref in max or autocad? i never do xrefs at max, but i will try thanks Link to comment Share on other sites More sharing options...
Visual Pieces Posted June 3, 2004 Author Share Posted June 3, 2004 plan view of urbanization Link to comment Share on other sites More sharing options...
Visual Pieces Posted June 7, 2004 Author Share Posted June 7, 2004 so... when u xref in max and copy 300 times, it upload your file exactly as the original file? with textures aplied perfectly? thx Link to comment Share on other sites More sharing options...
STRAT Posted June 7, 2004 Share Posted June 7, 2004 of course. thats what an xref is Link to comment Share on other sites More sharing options...
Visual Pieces Posted June 8, 2004 Author Share Posted June 8, 2004 u think i could manage this type of file with a athlon xp 2200/512/fx5200? and make animations in a reasonable time? Link to comment Share on other sites More sharing options...
Visual Pieces Posted June 8, 2004 Author Share Posted June 8, 2004 the prototype file is around 400 kb, if I erase the faces that are hidden using delete in editable mesh, it CAN REALLY HELP to make the file less heavy? Link to comment Share on other sites More sharing options...
Visual Pieces Posted June 8, 2004 Author Share Posted June 8, 2004 I xref the scene, it appears in the new scene (wich will contaiin the 300 copys) , but i cant select it! i need to copy and move/rotate the copies. i make a box as bind object, but it is the bind object of 1 xref. how i make to copy the xrefs 300 times without to have to insert it 300 times and make 300 boxes ?????? please i need help Link to comment Share on other sites More sharing options...
Sawyer Posted June 9, 2004 Share Posted June 9, 2004 This is how I would set up this scene 1 Create a file that has a full size site plan & use this as an xref "scene" into all of your files. 2 model the buildings seperatly 1 in each file. 3 create a new file for each street or block or whatever division you need to seperate your file into chunks. 4. layout the buildings onto the site using xref "objects". seperating the site into divisions allows for easier file sizes. 5. xfref "scene" all of the streets that you layed out into one file. Render that. xref object places individual objects from another file into your scene. xref scene places the file into your scene and makes it untouchable Link to comment Share on other sites More sharing options...
tranvietanhtuan Posted June 15, 2004 Share Posted June 15, 2004 it's very harmfull for your PC. i have done a projects like that last year. If you need some normal views or normal camerawalk thru' just use the RPC creator. Make the house come to RPC object. very fast rendering. But if you need bird views try as Sawyer said. Kind regards, Tuan Link to comment Share on other sites More sharing options...
visualasylum Posted June 30, 2004 Share Posted June 30, 2004 I have done something similar. These are the keypoints for you to consider. If you're going to have an animation showing the whole thing in general, no details will be visible at a far camera position. So consider modeling a few houses using map/texture techniques, that way it will save you lots of time when rendering. If you need to zoom in closely from far away, consider animating the highres model in at proper time. If you're going to use lots of trees, use Forest Pro plugin(itoosoft) to help you with this. Now if you have to plan this animation, plan it before hand, and make sure for close-up shots you don't have all those models on, otherwise your rendering time will suffer. I believe there's a scipt that doesn't consider the polygons that are not in camera view. you might have to search scriptspot. cheers, G Link to comment Share on other sites More sharing options...
omar Posted July 3, 2004 Share Posted July 3, 2004 hi visualasylum I just rendered this last night I had no problem at all one file no exref no instnces I even used vray GI Link to comment Share on other sites More sharing options...
