WIP: Tropical garden
STUNNING!!!!! & WOW
Question/s- Using projector map/s for Direct lighting? Using two lights for direct?
The top right has the best effect of lighting, it maybe just me, but is there something a little off between the White & Yellow of the lighting (bright GI & True direct). Can't pin point it to explain better, what do you think?
On the broad leaves are you using anything special like a falloff for the specular?
Having read your tutorials, I can see how it's all model'd and yet the level of realism is stunning, a masterful blend of materials, lighting, modeling.
rgrds
WDA
Thanks man!!
There are 4-5 omni lights in the scene as this is just a light test. You are correct that I use dent map as projector map for sunlight.
Most of the leaves material are gradient ramp but no fall off. and I choose "scratch.jpg" for specular map of big leaves :) :)
Montree
If you get any more talented you are going to simply explode.
PLEASE DON'T!!!!! We need you to keep inspiring us with your work!
Modeling question, (I'm feeling Inspired) - Palm frons did you poly model from something like edge /extrude or is it a converted spline?
p.s. really like the mapping (opacity) for the holes in the leaves outstanding detial!
brgrds
WDA
Looking really good.
Could use a bit more details where the coconut leaves join the trunk.
But your frangipanni is excellent. You going to show us the entire tree?
Thanks,
Yes and I am setting up a scene with all the plant that I draw, in. What I imagine is that I will try to create an environment scene with a little tropical architecture and landscape sense. :):):)
The wireframe of the very first plants
This is another closed-up view of the flower. I still need to adjust the proportion of the leaf and the flower.
The closed-up view and texture of the trunk.
In the mean time, i am also drawing a new trunk but havn't finished it.
