maxkid Posted June 7, 2004 Share Posted June 7, 2004 hi guys, When i import splines from microstation 7 to 3d max6 splines are very heavy in terms of no of vertex for each segment ,is there any way I can optimise them in terms of no of vertex points in the line in 3d ,if i manually go to delete it affects the curvature when viewed from top and front view since most lines are for bridges and so ,the reason why i am saying this is my rpc cars running on these slopes tend to jitter due to great no of vertex ( they are path constraint ) so is there any way i can optimise splines ( like how we optimise meshes in 3d ) so that my geomatry which is lofted along this path is more smooth and more imp less dense.....pls reply back your help would be highly apprecited..... maxkid Link to comment Share on other sites More sharing options...
Chad Warner Posted June 7, 2004 Share Posted June 7, 2004 There is a modifier called "normalize spline" that allows you to set the distance between points on the spline. Try that. -Chad Link to comment Share on other sites More sharing options...
STRAT Posted June 7, 2004 Share Posted June 7, 2004 http://www.boomerlabs.com/freeware.html scroll down to RE-SPLINE Link to comment Share on other sites More sharing options...
maxkid Posted June 7, 2004 Author Share Posted June 7, 2004 yeah checked it but they have yet to come out with max 6 ,thanks anyways i appreciate it, if you can think of anything else let me know , thank u once again Link to comment Share on other sites More sharing options...
STRAT Posted June 7, 2004 Share Posted June 7, 2004 use the max 4/5 version. it should work fine in max 6. Link to comment Share on other sites More sharing options...
