Jape Posted June 9, 2004 Share Posted June 9, 2004 Hi all, im having difficulties putting a logo on a wall while using the blend material, For the wall im just using a procedural text, and for the police logo im trying to put on a jpg, with an aditional mask. Somehow i cant get it to show up right, i've tried using a composite material, but that did'nt work either, is it beceause im using a procedural for the main material instead of a map ?? Would it be better to just clone the part where i want my logo on and opacity map it so i wont have to use a blend material ??? any suggestions are appreciated., ps. Screenshot attached Jape, Link to comment Share on other sites More sharing options...
Jape Posted June 9, 2004 Author Share Posted June 9, 2004 oh darn, forgot to put in the mix amount, still leaves me with the problem of the logo repeating all over, is there any solution for this ??? Link to comment Share on other sites More sharing options...
Brian Cassil Posted June 9, 2004 Share Posted June 9, 2004 You should be able to do this with a blend material but you need to load a mask instead of using the blend percentage. Then you also need to turn tiling off in the police logo image as well as in the mask and then use the offset values in those to control the placement of the logo. Good Luck! Link to comment Share on other sites More sharing options...
Jape Posted June 9, 2004 Author Share Posted June 9, 2004 Ah yes, got it, works like a charm !! Thanx !! Link to comment Share on other sites More sharing options...
