JAVB Posted June 9, 2004 Share Posted June 9, 2004 How do I create a chain link fence using Autodesk VIZ4? Any help would be appreciated. Thanks. Link to comment Share on other sites More sharing options...
kainoa Posted June 9, 2004 Share Posted June 9, 2004 Do you need to model the chain link in detail? Or will the fence just be part of a larger scene? If it's just a part of a scene, you can get away with an opacity map. Create a plane object, apply a grey material (use a bitmap with a cross-hatch pattern as an opacity map). Then just create cylinder objects for the posts. Voila! If you reeeeally need to model the chain link details, then I would just model one section of the link by lofting a circle along a path. Then I'd use the array command to instance the section to create an entire fence. Hope that helps. Link to comment Share on other sites More sharing options...
IC Posted June 10, 2004 Share Posted June 10, 2004 Map these onto a flat plane. First one in the opacity or clip channel and the other in the colour and bump. Link to comment Share on other sites More sharing options...
Buffalo Bills Posted June 10, 2004 Share Posted June 10, 2004 Nice chain link maps! Did you create those or did you download them from a site? I created a chain link fence in a sipmle version of that. I think I like your better. Link to comment Share on other sites More sharing options...
IC Posted June 10, 2004 Share Posted June 10, 2004 I downloaded them from somewhere(can't remember where- it was a long time ago) They work really well though. Link to comment Share on other sites More sharing options...
JAVB Posted June 10, 2004 Author Share Posted June 10, 2004 The chain link fence I am trying to create is for a larger scene. Thank you all for your help and comments. I will give it a try. Thanks! Link to comment Share on other sites More sharing options...
STRAT Posted June 10, 2004 Share Posted June 10, 2004 aye, if it's not to be a close up and it's for a larger scene then opacity mapping is the only answer. Link to comment Share on other sites More sharing options...
Psychoscorpic Posted June 12, 2004 Share Posted June 12, 2004 Remember to make the Material 2-sided so that the fencing renders both sides if it goes around a corner, and to cast proper shadows. Link to comment Share on other sites More sharing options...
JAVB Posted June 25, 2004 Author Share Posted June 25, 2004 Thanks for all of the suggestions and help! It worked well, see quick render below: Link to comment Share on other sites More sharing options...
Buffalo Bills Posted June 25, 2004 Share Posted June 25, 2004 Can't see the quick rendering?? :-) Need to attach it. Link to comment Share on other sites More sharing options...
