Wall with slope - degrees?
Andronikos
Hi
I forgot to check the forum section. Any way we work with ADT and Viz 4.0. Same problem we also get in sloping walls. No option as such in ADT.
Such kind of instances I generally do 3d modeling using AutoCAD solids.
This won't help you any way...feel like sharing.. :)
Draw your wall...
Then select Extras > Accessories > Wall Accessories...
This will add the custom settings to the Wall Settings dialog box and allow you to edit the wall profile. You can still insert doors and windows into it.
Hope this helps.
  • 4 months later...
