Dirt Map
trhoads
Hello all,
I have been told that adding a dirt map to a rendering that I am working on, would help loose some of the "too clean" feel. Does anyone have a way to do this without another program? I have seen other programs that do this, but purchasing another program is not an option. I am using VIZ 3i, yes I know, I need to get with the times, but I would really like to explore this option, just not sure how. :confused: ANY help would be greatly appreciated. Thanks in advance.
What I usually do is to create a blend material. Put your primary material in the first slot (paint, stucco, or whatever) and use smoke or noise in the mask slot. Then in the second slot put in a copy of the primary material (again the paint, stucco, or whatever) mixed with a generic dirt, concrete, or other blotchy ugly bitmap. You can use the mix map type for this. This sounds a little confusing typed out like this, if I have time I'll create a little diagram of how this would work.
  • 3 weeks later...
