Professor Posted May 27, 2010 Share Posted May 27, 2010 I'm trying to set up a Hotkey for Quick Planar Map command (the one under the Unwrap UVW modifier). Normally I go to Customize and then find the command under the Keyboard tab and add a Hotkey, but I can't find this command listed anywhere. Does anyone know how I can setup a Hotkey for this command? If I need to make a Maxscript, then it probably will have to wait as I don't know Maxscript yet, but will get there. Thanks! Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted May 27, 2010 Share Posted May 27, 2010 in customize, if you pull down the 'Group' (Defaults to Main UI) and set it to Unwrap UVW, the quick planar is in there Link to comment Share on other sites More sharing options...
Professor Posted May 28, 2010 Author Share Posted May 28, 2010 Thanks Dave! Link to comment Share on other sites More sharing options...
