creating waterfall
colorID
hello again,
thnx for ur attention.
well it is part of a club house context where the water falls on rocks artificially arranged in different levels and then the water continues to run to reach a swiming pool.i think it should appear like some bubles but it is absloulty quit one,and smooth moving.
thnx again
best regards
If you are considering animating it, and if you ever think you will be doing fluid effects again, I would highly recommend the Next-Limit software. I got it about a year ago and have used it in a few animations and it really works great. Not cheap mind you $1000 or maybe more. But if you do that kind of work much, it's worth it. We seem to be putting waterfalls in just about everything lately so I'm glad we have it.
If you do decide to use particals I'd look in to a tutorial on making bubbles with particals.. I think thats the tutorial I used. In the tutorial I looked at once it told how to attach a bitmap to particals..And some how we got it to blur just right...Then for the bubbles that are made from the flowing water use another partical (spray or what ever works) pointed up with the bubble map attached to it. And keep it in the water pretty low so just a few particals touch the top...It's been a while since I did a water fall... cool2.gif
