Distributed Render problems with Max 2010
teophyl
Hi!
I'm not a technician, so I could did something wrong. I have max 2010, vray 1.50 sp4, win xp 32bit.
Distributed Rendering doesn't work. On render slaves the dr spawner starts, and max+vray works well on the master machine. The VRay messages window says on rendering: "Using 0 hosts fos distributed rendering." Although, on DR settings panel max 2010 shows the slaves IPs, so it sees them.
I tought there would be problems with the router settings or firewalls. So I started the vray spawner and max 2010 on the master pc, but the spawner doesn't start working. Just still in stand by (vraydummy on taskbar...). This method (starting th spawner and max on the same pc) works with max 2009+vray.
So I don't know what could be the problem. I read on several forums that there are problems with DR in max2010+vray150. Chapsgroup selling an expensive software that doesn't work?? I don't think so.
So what now?
Thanks for Your replys!
  • 1 month later...
