Lisence Transfer Utility
I can't seem to get the LTU to initiate. Genuine copy of 2010 Max Design. I've used it once before on these same machines but for some reason it won't even start on one of them now. I just get the egg timer for a couple of seconds then nothing. Any suggestions would be greatly appreciated.
Sounds like a corrupted install. Would try one of two things.
1. Contact Autodesk directly to see if they have run into this before and if there is a work around for the problem.
2. Re-install the software.
Re-install is a last resort. You will loose any customization that you may have created unless you save out the cui file.
Good luck with it.
