creating angles problem
reptar
Hi, i am trying to draw up a lot to import the linework into 3D Max. I am playing around with a site plan but am having difficulties drawing this in AutoCad. When i enter in the degrees/minutes and length using the line tool my drawing looks nothing like the attached image. Do i need to alter my North/South/East/West? Any tutorials out there? I am very new to autocad so please bare with me.
Cheers,
Hi Peter. You need to set AutoCAD up with Surveyor whole circle bearings. That is; north is 0 degrees and angles are measured clockwise. Use the units command to alter the AutoCAD bearings as per attached. If you were to start at the top left corner you enter the dimension as @31500
the second point would be @43060
...and so on.
Hope this helps
