helenistikyay Posted June 9, 2010 Share Posted June 9, 2010 any comments are welcomed 3dsmax + vray Link to comment Share on other sites More sharing options...
aristocratic3d Posted June 9, 2010 Share Posted June 9, 2010 Mashallah, great render. trees seams to be from evermotion. or else? confused. Link to comment Share on other sites More sharing options...
Jason Matthews Posted June 10, 2010 Share Posted June 10, 2010 Nice image for the most part. Overall the image lacks visual interest mostly due to lack of people and activity. The GI is a bit washed out IMO. There does not appear to be much contrast between the direct lit areas and the indirect lit areas. Are you ising HDRI or Vray sun/Sky? The bushes and shrubs repeat too much and I think you may need some additional plants, shrubs, and trees maybe with different colors. The concrete curbs need some attention. Also, the pattern repeats quite often. Change the red lights so that some are green. Are the reveals in the stucco supposed to be light or should they be the same color as the stucco. I think you may also benefit from doing an ambient occlusion pass to pull out some of the detail. I think it may also help with your stucco as well. Link to comment Share on other sites More sharing options...
alywhosane Posted June 20, 2010 Share Posted June 20, 2010 Nice work, I agree with Saturn it'll look pretty good with the AO Pass will definitly bring out the image as for the Curbs n pattern repeating you can work it out em sure.. and please check ur Signal Lights ur BENZ is going against the traffice..... good work .. Link to comment Share on other sites More sharing options...
alejandroserranomonforte Posted June 21, 2010 Share Posted June 21, 2010 some postwork in ps nice render ismail Link to comment Share on other sites More sharing options...
