Winter Posted June 21, 2004 Share Posted June 21, 2004 I've just upgraded to Viz 2005 and opened up a scene I did in viz 4 using radiosity. For some reason the scene is now rendering really dark - I've messed with the exposure and increaed/descreased the physical scale to no effect. I've done a re calc on the radiosity, ensured that I'm using the scanline renderer (as in Viz4), made sure the units are the same as previously (mm) and STILL the scene is dark. I must be missing something really simple - What is it? Link to comment Share on other sites More sharing options...
Fran Posted June 21, 2004 Share Posted June 21, 2004 Hi Neal, With Viz 2005, Ambient and Diffuse colors need to be locked in your materials. I have changed them without having to re-run the solution. Link to comment Share on other sites More sharing options...
abicalho Posted June 21, 2004 Share Posted June 21, 2004 Fran is correct. And that's why there's a utility called "Fix Ambient" in VIZ 2005. Go to the Utility Panel > More... > Fix Ambient > Find All > Fix The Radiosity will say it's invalid, but it's not a problem. Just re-render and you should be good to go. Alexander Link to comment Share on other sites More sharing options...
Winter Posted June 21, 2004 Author Share Posted June 21, 2004 Thanks - it was bound to be something simple! Link to comment Share on other sites More sharing options...
