css20xx Posted June 13, 2010 Share Posted June 13, 2010 (edited) Hello! [ATTACH=CONFIG]37551[/ATTACH] I need to have a parametric "Rectangle" (because i want to modify it) with a modifier "Edit Spline" ( or other modifier that can do this ) to which I can add a Vertex "Bezier" with "Refine" ( or other method ), and move that vertex up. I try in this way, but is not complete, i know: ------------------------------------------------------- rt = rectangle width:100 length:100 es = Edit_Spline()--create an Edit_Spline modifier addModifier rt es --add modifier to the rectangle max modify mode --switch to modify mode select rt --select the plane ------------------------------------------------------- but further, i don't have a clue. Maybe someone can help me. Thanks! Edited June 13, 2010 by css20xx Link to comment Share on other sites More sharing options...
