DR Render Servers Dropping VRay Dome Light HDRI
erickdt
Hello All,
I was wondering if anyone has run into this problem before. For some reason my DR nodes are dropping the VRay HDRI texture I have inserted into a VRay dome light. Does anyone know why this is happening or what the solution is. The HDRI file is located where all the nodes can access it so I should be all good there. Any suggestions would be greatly appreciated!
E
So the plot thickens... I also notice that my proxy objects are getting dropped. The wierd thing is that frames render correctly on backburner proxies, hdri and all. So then this seems to be a DR issue. I'd still like to know why this is happening as I usually use a render node to speed up preview renders and would hate to loose that advantage.
E
