mohsen123 Posted June 18, 2010 Share Posted June 18, 2010 hi there . I have a line and when I use outline for that, some points go wrong (attached image)... I find some solution to use sweep modify and convert to edit poly and create some parallel splines from ... but is this the best solution ?any Idea ? thanx. Link to comment Share on other sites More sharing options...
Claudio Branch Posted June 18, 2010 Share Posted June 18, 2010 I would suggest that you create your spline, make it renderable, convert it to Editable Poly and then use the Loop/Create shape from selection.... Link to comment Share on other sites More sharing options...
mohsen123 Posted June 19, 2010 Author Share Posted June 19, 2010 hi Claudio Branch thanx for replay is there any solution to do something with spline....to convert them to edit poly and then convert to spline is what I was test. Link to comment Share on other sites More sharing options...
