Urgent help needed object not moving!
djoshi
Strange happening in max 2009.
Objects are getting created at 0,0,0 & it creats keys at start & end. after creating object it cant be moved..??:confused:
Pls. help urgently..stuck in between of urgent project..
Thank in advance..!!
It sounds like your default position controller type got set to "Path Constraint" that controller automatically sets a keyframe at the first and last frame, and until set to a path, the object has no way of holding XYZ position data. Go to the motion panel, and select the position controller and change to a "Position XYZ" and things should be back.
Hope this helps,
-Nils
