Chad Warner Posted June 18, 2010 Share Posted June 18, 2010 I've got several editable polys imported from sketchup into MAx 2010 that has multiple materials applied to it, that I'd like to be able to split up by material (Not necessarily MatID, because the object may have 3 ID's that are all one material). Is there an easy way to do this? Thanks, Chad Link to comment Share on other sites More sharing options...
Chad Warner Posted June 18, 2010 Author Share Posted June 18, 2010 Nevermind, found a script on scriptspot:http://www.scriptspot.com/3ds-max/scripts/detach-by-material-id I wasn't using the right keywords before so nothing came up. Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted June 18, 2010 Share Posted June 18, 2010 I use that one a lot.. it has a couple bugs though, run it on a not too huge set of objects (say, under 2000) or it can run out of ram and crash/lockup the delete objects thing doesn't actually delete the host objects in most cases, so i run a second script after to delete empty meshes sel = selection as array for obj in sel do if (obj.numfaces == 0) do delete obj sometimes it skips objects? So i just run it a couple times. anyway!! script comes in handy, if you're feeling annoyed at multisubs with the new slate material jam like I am. Link to comment Share on other sites More sharing options...
