stormchaser Posted June 19, 2010 Share Posted June 19, 2010 hi mates, i am doing this project that requires grooves in the plaster in brick pattern, so i applied a vraydisp mod and using a tile map. but i am not getting the desired result, its all blurry. i am attaching two images, one is with the tile texture in diffuse slot without vraydispmod, other is with vraydispmod on using the same tile texture. i have tried almost everything, i have set the blur value to .01 in map option, turned off filtering, reduced the edge length to .5px in vraydispllacement settings. but nothing is helping. Link to comment Share on other sites More sharing options...
Chad Warner Posted June 19, 2010 Share Posted June 19, 2010 are you using 2d displacement or 3d? I don't know if that's the problem, but try switching from one to the other to see what result you get. Link to comment Share on other sites More sharing options...
Jason Matthews Posted June 19, 2010 Share Posted June 19, 2010 Make sure the displacement map is scaled correctly. Looks too large. Link to comment Share on other sites More sharing options...
stormchaser Posted June 20, 2010 Author Share Posted June 20, 2010 i am using 3d displacement, and the map is procedural so it cant be scaled too large. regards Link to comment Share on other sites More sharing options...
alejandroserranomonforte Posted June 21, 2010 Share Posted June 21, 2010 for this texture you can simply use bump Link to comment Share on other sites More sharing options...
aristocratic3d Posted June 22, 2010 Share Posted June 22, 2010 Simple bump should work really. try that. Link to comment Share on other sites More sharing options...
