maxkid Posted June 22, 2004 Share Posted June 22, 2004 hi guys, I rendered images jpg format from 3dmax about 5,000 frames using backburner ( network ) when i import them in after effects it gives the message 39:44 frames missing ,this does not mean frame 39 or 44, it is an error message , is there a way to find out which are the frames not rendered in after efx or any utility ,if i go through explorer it takes far more time , eveytime i have to render an avi to find which frames are again and then render the avi once i know which frames are missing from the avi......... darshan Link to comment Share on other sites More sharing options...
STRAT Posted June 22, 2004 Share Posted June 22, 2004 why dont you just thumb-nail browse the image directory in Explorer or paintshop pro? that should tell you the missing frames. Link to comment Share on other sites More sharing options...
John Dollus Posted June 22, 2004 Share Posted June 22, 2004 Another tip would be to open your directory and resize the window so only 10 files or so show up in each column. By just scanning across the bottom, the odd numbers will stand out. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted June 22, 2004 Share Posted June 22, 2004 i've ran into this problem several times before. what software are you using? several have options in the rendering dialog that say something like 'don't re-render existing frames' or 'skip existing frames', or somehting along those lines. sheck this, and your app should find the missing frame without a problem. although in the past i looked for a utility to do this, i never found one, but i am interested in one if someone else has. http://www.cgarchitect.com/vb/showthread.php?t=5487 . Link to comment Share on other sites More sharing options...
pmanahan Posted June 22, 2004 Share Posted June 22, 2004 I have had the same problem before and the way I solve it is to load the batch images into after effects and save out as a movie. The rendering process will stop on the missing frame or it will render a color bar image in it's place which shows up when you play the movie. pmanahan Link to comment Share on other sites More sharing options...
maxkid Posted June 24, 2004 Author Share Posted June 24, 2004 thank u guys, i apprecite it Link to comment Share on other sites More sharing options...
