landrvr1 Posted June 21, 2010 Share Posted June 21, 2010 Watch this vid. The guy converts what looks to be a somewhat poly heavy series of meshes into a proxy, but then gets ZERO POLYS. ??? WTF ??? I'm at a total loss to explain how this is possible. Maybe I just don't understand how to create a proxy??? How does one get down to ZERO POLYGONS? lol. Link to comment Share on other sites More sharing options...
Dave Buckley Posted June 21, 2010 Share Posted June 21, 2010 a proxy is essentially just a referenced file that is loaded at render time, because it's loaded at render time then it's technically not in your scene while you work meaning it will show as being zero poly's as it doesn't exist until you hit the render button check the tutorials that ship with max Link to comment Share on other sites More sharing options...
landrvr1 Posted June 21, 2010 Author Share Posted June 21, 2010 Well, I'm been using proxies for quite some time but I've NEVER seen them at zero polys. In fact, just one proxy using bounding box view is going to naturally show up as at least 12 polys. I don't get how this guy gets ZERO. ?? In fact, given what proxy files are, why would there not always be zero polygons in the stats list?????? Watch that vid. Link to comment Share on other sites More sharing options...
Dave Buckley Posted June 21, 2010 Share Posted June 21, 2010 Are you sure you'd have polys from a bounding box? Polyst make geometry. A bounding box isn't geometry is it? Link to comment Share on other sites More sharing options...
BrianKitts Posted June 21, 2010 Share Posted June 21, 2010 That's really odd.... I have no idea how he did that, because when you add a vray proxy to your scene you'll have the number of polys that you set in the mesh export options for the "faces in preview" value of the proxy. Even if you switch the proxy display to bounding box you have 12 polys, and switching the preview to a point, you still have one vertex and one poly. I'm dumbfounded. might be a good question to throw on the chaos group forums. Link to comment Share on other sites More sharing options...
Dave Buckley Posted June 21, 2010 Share Posted June 21, 2010 its the same with mental ray i just converted a simple teapot to a proxy then deleted them both out of the scene so scene contained nothing reloaded the proxy back into the scene and pressed 7, the result is below Link to comment Share on other sites More sharing options...
aristocratic3d Posted June 22, 2010 Share Posted June 22, 2010 Really I good tutorial. thanks scott for posting the issue and thanks Dave to make it clear. Link to comment Share on other sites More sharing options...
aristocratic3d Posted June 22, 2010 Share Posted June 22, 2010 Hi guys, I gave it a try but was not working for me! and also I was not able to retain my textures. When I save a file into vray proxy and load it, it loses texture and does not show that 0 vertexes. Link to comment Share on other sites More sharing options...
Dave Buckley Posted June 22, 2010 Share Posted June 22, 2010 proxies don't retain textures so there is nothing weird going on there, i usually texture the object before converting to proxy and then save the objects material to my library, that way when i reload the proxy i can just reapply the pre made mat to it Link to comment Share on other sites More sharing options...
aristocratic3d Posted June 22, 2010 Share Posted June 22, 2010 What do you do when you got a procedural mat and a texture on the same object? I converted one of my object to proxy which contain a glass mat too. so I just cant use glass or any other material ? Or do I need to detach first and then export them? I hope this is not the only way to save different mat! Link to comment Share on other sites More sharing options...
Dave Buckley Posted June 22, 2010 Share Posted June 22, 2010 can't you attach them and do it as a multi-sub object mat? Link to comment Share on other sites More sharing options...
