How can we produce a plan like this
muchhal.sandeep@gmail.com
there is nothing there in selection 3 it's just stuff for the bathroom Kitchen etc.
if you want to create a floor plan then you will need to learn the basic to box modeling or AEC externded none us have the time to teach you i would do the tutorials that come with max once you have done them then you will know how to create a floorplan using box modeling or aec extended. You cannot learn max in 5 minutes it takes day, months or years.
Edited by datacrasher
Hi
thr is some confusion
just there at the right bottom of 3 rd option there
1 st start a new home
select any house and right bottom of screen upgrade to your home
it clears our second stage
on right bottom of screen click on review home
it gets us to the fourth stage
which shows us a plan
this plan can be rotated and its tilt can also be changd as it is mentioned below the plan
we can use our mouse pointer for it
and for tilting we need to use the slider bar at left bottom
Hi
no its not so
we dont intend to copy the plan
we have got our own set of drawings for some of our projects
we just need to show them the same way as these ppl are showing
just similar method of presenting the plan
not copying the plan
so you want too add a floor plan to your viewport? you need to get authorization from the ppl who own the site if you don't that illegal unless you own the site then i will possible help you
then you need to first draw the plan on a paper if you have done that you eaither need to do the same in photoshop or a similar application to photoshop or you need a scanner to scan it on your computer save the scan in jpeg open up max. load the image into the top viewport by using the alt and the B key. now use the dropdown menu where it says "file" locate where you save your jpeg image once it's loaded it to the file section click on ok
in the aspect ratio put the dot in match bitmap image on the right hand side of that box your see background lock/zoom/pan make sure these are checked ( ticked). in the viewport make sure you have the top viewport selected. Now click on okay, max will load the image into the top viewport now you can start modeling
Good luck
Dc
I think the package you are looking for is called silverlight. There is a company called Aarkid that do development work in this. But you can create a similar type of presentation with acrobat, flash, or quicktime quite easily. These actually provide a complete 360 solution. You can simply import your .3ds model into acrobat and voila
Hi
I will try this process
and will comeup with a feedback asap
thaanks for your concern
Agree, but glancing at the source code, I think the site was done in Flash, not Silverlight.
Easy way... Quicktime Object VR, maybe Acrobat*
Harder way... Flash
Hardest way... Silverlight
*Not sure if PDF can be embedded for inline viewing.
Edited by Crazy Homeless Guy
Sandeep.. It is probably done with some flash 3d engines like papervision3d or away3d. I dont know exact procedure of building it.
I dont know whether you remember me or not...im karthik skumar from kerala..doing realtime 3d vrwalking..
I think i can give such service...please see....
http://forums.cgarchitect.com/61035-unity-based-virtual-studio-apartment.html
Edited by gfxguru
