How to use maximum ram for the rendering
sanmb
sanjay.
first question is what are you modeling? i would not maximum out the render because this could crash your computer unless you have have a lot more memory in it....
If you do want to max out the render then i would turn on the GI's FG set them too high, add some animation to your scene, More models and lights but not too many because this could over-expose and the render would look rubbish. also attach an image.
precise question = precise answer
If you render 1 box with simple material and 1 light on a workstation with 10000000GB ram, Max will use only 1GB or even less. If the scene will have billions of polygons and gigabytes of textures it will use proportionally more ram.
The memory management is not perfect but you can't ask for it to use more than it needs....
