ReneRumberg Posted June 29, 2010 Share Posted June 29, 2010 (edited) How can I get rid of this grain and glossy effects and how can i make floor and other details to come more out + how can I get rid of those spotlights on the back wall? I'm still kind of beginner with the vray and I'm learning step-by-step. Edited June 29, 2010 by ReneRumberg Link to comment Share on other sites More sharing options...
aristocratic3d Posted June 29, 2010 Share Posted June 29, 2010 These might have caused by lot of thing. a specific problem is easy to solve. you better see more tutorials. Post the render set up. also a little description about scene scene properties like how manu light did you use. what are the parameters etc. Link to comment Share on other sites More sharing options...
anejo Posted June 29, 2010 Share Posted June 29, 2010 You may want to start by using the standard universal vray settings, and than adjust from there. http://www.spot3d.com/vray/help/150SP1/tutorials_unisettings.htm Link to comment Share on other sites More sharing options...
Brian Smith Posted June 29, 2010 Share Posted June 29, 2010 fyi, it's a pretty easy fix and is discussed in great detail in 3 hours of free video training available here http://3dats.com/free/ Link to comment Share on other sites More sharing options...
ReneRumberg Posted June 29, 2010 Author Share Posted June 29, 2010 You may want to start by using the standard universal vray settings, and than adjust from there. http://www.spot3d.com/vray/help/150SP1/tutorials_unisettings.htm Hi. Thanks for the nice link. But I have one question. Over there it says "7. In the DMC sampler rollout, set the Adaptive amount parameter to 1.0. Typically you will also need to adjust the Noise threshold as the default may produce too much noise. A good value is, for example, 0.005." When I go under DMC sampler then there is no such a thing even. http://i46.tinypic.com/ostis9.jpg Link to comment Share on other sites More sharing options...
John Dollus Posted June 29, 2010 Share Posted June 29, 2010 (edited) instead of looking under the Adaptive DMC image sampler in the antialiasing section of the main Vray tab, look in the Settings tab under Vray:: DMC Sampler Edited June 29, 2010 by John Dollus typo Link to comment Share on other sites More sharing options...
