How do get rid of the grain?
ReneRumberg
How can I get rid of this grain and glossy effects and how can i make floor and other details to come more out + how can I get rid of those spotlights on the back wall? I'm still kind of beginner with the vray and I'm learning step-by-step.
Edited by ReneRumberg
  anejo said:
You may want to start by using the standard universal vray settings, and than adjust from there.
http://www.spot3d.com/vray/help/150SP1/tutorials_unisettings.htm
Hi. Thanks for the nice link.
But I have one question. Over there it says "7. In the DMC sampler rollout, set the Adaptive amount parameter to 1.0. Typically you will also need to adjust the Noise threshold as the default may produce too much noise. A good value is, for example, 0.005."
When I go under DMC sampler then there is no such a thing even.
http://i46.tinypic.com/ostis9.jpg
