zewanil Posted June 30, 2010 Share Posted June 30, 2010 Hi there i am looking for a way to present my work as a drafting before all the texture is there a way i can render a scene by not removing all the texture and render it as a drafting Like this image from evermotion thanks guys P. Link to comment Share on other sites More sharing options...
JamesL Posted June 30, 2010 Share Posted June 30, 2010 If you're using Vray, go to the Global Switches rollout in the render settings and check 'Override Material' - fill the slot with a plain grey/white material (a default vray material works fine). Causes a problem if you have real glass windows as they will be grey too - so either hide them or exclude them in the Override option. Link to comment Share on other sites More sharing options...
Tommy L Posted June 30, 2010 Share Posted June 30, 2010 Use the material override in the render panel (Global Settings). Drag whatever material in there from the mat editor. Looks like the example you posted either uses an edge texture or used toon render in the environment settings. Using the override you will not lose your materials. I use used more often for testing lighting than anything else. Or just giving the client something to look at whilst Im doing stuff. Link to comment Share on other sites More sharing options...
JamesL Posted June 30, 2010 Share Posted June 30, 2010 In actual fact its similar in Mental Ray too - its in the 'Processing' tab under the 'Translator Options' rollout. Link to comment Share on other sites More sharing options...
zewanil Posted June 30, 2010 Author Share Posted June 30, 2010 thanks for reply ... by override the scene with overide material .. i get a 3d scene with white material .. i would really like to have the '' drafting effect '' . what is the toon render ? or a edge texture thanks for replying ? Link to comment Share on other sites More sharing options...
zewanil Posted June 30, 2010 Author Share Posted June 30, 2010 ok guys i just found out vray toon wow .. cool ... what a tool its perfect have a good day everyone P. Link to comment Share on other sites More sharing options...
JamesL Posted June 30, 2010 Share Posted June 30, 2010 Yeah, Vray toon is one option - as Tom said, the other good option is to use VrayEdgesTex in your Override material (drop in in your diffuse slot, tweak the colour as you like...) - I'd recommend changing the Thickness to world and adjust the scale accordingly (probably will require a test depending on your units setup) Link to comment Share on other sites More sharing options...
